coq-club - Re: [Coq-Club] quotients
chronological Thread
  • To: Carlos Simpson <Carlos.Simpson AT unice.fr>
  • Cc: Andrew Cave <acave1 AT cs.mcgill.ca>, Victor Porton <porton AT narod.ru>, Thorsten Altenkirch <txa AT Cs.Nott.AC.UK>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] quotients
  • Date: Wed, 9 Nov 2011 14:38:08 -0500 (EST)
On Wed, 9 Nov 2011, Carlos Simpson wrote:
I would claim that there is a difference between being sometimes interested in
types with computational content; and requiring *all* types to have
computational content. Regarding R and Q: let Q' be the type of 1-element
subsets of Q, which if we assume proper quotients, can be defined. Then
we can define non-constant functions R-> Q'. The projection Q->Q' is
bijective but doesn't admit an inverse, since Q has decidable equality but
not Q'. Or in another direction, given a quotient
X/r, you can still look at the setoid (X,r), indeed for some parts of
the discussion it will undoubtedly be essential to do so.
Assuming quotient types would just allow you to sometimes consider types
which aren't setoids.
What you suggest above is fine. In fact, the tick in Q' is almost the same as what I call the classical value monad in my paper, "Classical mathematics for a constructive world", except that I use (double negation) stable setoids instead of quotients and require the 1-element predicates to be stable. The Kleisli arrows for this classical value monad gives you a classical function space which lets you do most of your classical style mathematics. You even get classic definite description for classical (aka stable) propositions and hence classic definite choice as a theorem. (And furthermore, classical indefinite description is a consistent proposition and could be added to a type theory such as OTT without losing canonicity of the non-Prop universe.)
I don't immediately see any problems using a proper quotient type here instead of a stable setoid.
Using the classical value monad and classical function spaces is IMHO a great way for people wanting to do classical mathematics (such as Victor) to do so in constructive type theory (after all, constructive mathematics is *more* expressive than classical mathematics). You don't need to assume any axioms, so the work is usable for people doing constructive mathematics. As I point out in my paper, there are several examples of places in constructive mathematics where we want to use classical results.
But it is important to understand that, of course, you don't get constructive functions when you use classical function spaces and they won't be usable for computation.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
