- To: Dan Doel <dan.doel AT gmail.com>
- Cc: coq-club AT inria.fr, Andreas Abel <andreas.abel AT ifi.lmu.de>, Adam Chlipala <adamc AT csail.mit.edu>, AUGER C�dric <Cedric.Auger AT lri.fr>
- Subject: Re: [Coq-Club] Positivity and Elimination Principle
- Date: Fri, 20 Jan 2012 20:24:26 -0800
On Friday, January 20, 2012 06:14:32 PM Dan Doel wrote:
> On Fri, Jan 20, 2012 at 8:00 PM, Daniel Schepler
> <dschepler AT gmail.com>
wrote:
> > I probably know even less about Agda than you do about Coq, so I'm not
> > sure I understand the question, or all the details of what you were
> > saying below. The only eliminator restrictions in Coq, afaik, are that
> > you can't eliminate most Props unless the result is also a Prop (notable
> > exceptions being eq and Acc).
> That's the kind of thing I mean. There's another restriction when
> --impredicative-set is on that circumvents the fact that strong
> impredicative sums (and therefore impredicative inductive types) are
> inconsistent. The restriction prevents you from projecting out the
> large parts, at least usefully.
> Prop isn't large compared to Type, though, so I don't think that
> restriction would matter here.
> And your experiment substituting Prop with Type is essentially the
> situation in Agda. It only has the predicative hierarchy, and nothing
> comparable to Prop.
Ah, OK. Another issue is that if you go back and replace Prop with bool in
the original example, then injectivity of a map ((T->bool)->bool) -> T is
inconsistent with the axiom "classic_dec : forall P:Prop, {P} + {~P}". The
proof is pretty much the same, where you use classic_dec to convert certain
Props to bools.
I don't know whether that would be much of an issue in Agda; but in Coq, I
wouldn't want to lose the ability to formalize classical mathematics (and
have
the results be meaningful instead of just following from an inconsistency).
But then, I guess it's fairly well-known that classic mathematics is
inconsistent with an impredicative type system, at least if you want to be
able to have "constructor discrimination".
Daniel Schepler
- Re: [Coq-Club] Positivity and Elimination Principle, (continued)
Jean-Francois Monin
AUGER Cédric
Adam Chlipala
Andreas Abel
Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, Daniel Schepler
- Re: [Coq-Club] Positivity and Elimination Principle, Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, roconnor
Dan Doel
Andreas Abel
Adam Chlipala
AUGER Cédric
- Re: [Coq-Club] Positivity and Elimination Principle, Andreas Abel
- Re: [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
- Message not available
Jean-Francois Monin
