coq-club - [Coq-Club] Trouble reasoning about a well-founded program
  • From: "Harley D. Eades III" <harley.eades AT gmail.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Trouble reasoning about a well-founded program
  • Date: Fri, 14 Dec 2012 09:33:17 -0600
Hello everyone.
A while ago I formalized some of my research on the hereditary substitution
function in Coq. At first I tried to define the function in Set using
Program Fixpoint
and the wf annotation. I was able to define the function and satisfy all the
obligations.
However, I can't compute with it. Even worse the subgoals generated are
huge. They
are over 1000 lines long.
Here is the function definition I am using:
Program Fixpoint hsubst_t (s:trm) (x:nat) (CUT:typ * trm) {wf lex CUT} : trm
match CUT with
| (_,(trm_bvar x')) => (trm_bvar x')
| (_,(trm_fvar x')) => match (nat_compare x x') with
| Eq => s
| _ => (trm_fvar x')
end
| (T,(trm_lam T' t1)) => trm_lam T' (hsubst_t s x (T,t1))
| (T,(trm_app t1 t2)) =>
match (ctype T x t1) with
| Some (typ_arrow T1 T2) =>
let t1' := hsubst_t s x (T,t1) in
let t2' := hsubst_t s x (T,t2) in
match t1' with
| trm_lam T j =>
let free_vars := (FV_t j) ++ (FV_t t2') ++ (x::nil) in
let y := pick_fresh free_vars in
hsubst_t t2' y (T1,(open_t 0 (trm_fvar y) j))
| _ => trm_app (hsubst_t s x (T,t1)) (hsubst_t s x (T,t2))
end
end
| (_,trm_c) => trm_c
end.
I have a file which has everything in it here:
http://homepage.cs.uiowa.edu/~heades/notes/Coq/hered_subst.v.
Warning: it is an ugly file, but it all type checks. The function is at the
bottom of the file.
Is this the way I should be writing the program? I want to be
able to define the above function, prove it correct, and then
extract it to Ocaml. At the very least I would like to be able to
actually compute with the thing.
I need to be able to reason about this function. For example, this lemma
Lemma hs_fvar : forall n, hsubst_t (trm_fvar n) n (typ_base, trm_fvar n) =
trm_fvar n.
is trivial and I can't seem to prove it. Even worse the subgoal is 1200
lines long!
The issue is the fact that the termination argument is packaged up using
sigma-types
and interlaced into the program definition.
My main question is, is this the right way to do this?
Is there a better way?
In my formalization I got around all of this by working in Prop. I defined
the
function as an inductive proposition and proved it functional. However, this
cannot be computed with so I am not completely satisfied with
that formalization. In addition not being able to do this has been bugging me
so I thought I would ask the list.
Thanks for any feedback.
Harley
