coq-club - Re: [Coq-Club] Trouble reasoning about a well-founded program
  • To: "Harley D. Eades III" <harley.eades AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Trouble reasoning about a well-founded program
  • Date: Fri, 14 Dec 2012 19:53:15 +0100
Le Fri, 14 Dec 2012 09:33:17 -0600,
a écrit :
A lot of people have already replied to you.
But I can add some comment.
> Hello everyone.
> A while ago I formalized some of my research on the hereditary
> substitution function in Coq. At first I tried to define the
> function in Set using Program Fixpoint and the wf annotation. I was
> able to define the function and satisfy all the obligations. However,
> I can't compute with it. Even worse the subgoals generated are
> huge. They are over 1000 lines long.
> Here is the function definition I am using:
> Program Fixpoint hsubst_t (s:trm) (x:nat) (CUT:typ * trm) {wf lex
> CUT} : trm := match CUT with
> | (_,(trm_bvar x')) => (trm_bvar x')
> | (_,(trm_fvar x')) => match (nat_compare x x') with
> | Eq => s
> | _ => (trm_fvar x')
> end
> | (T,(trm_lam T' t1)) => trm_lam T' (hsubst_t s x (T,t1))
> | (T,(trm_app t1 t2)) =>
> match (ctype T x t1) with
> | Some (typ_arrow T1 T2) =>
> ┌─→let t1' := hsubst_t s x (T,t1) in
> ┏━┿━⇒let t2' := hsubst_t s x (T,t2) in
> ┃ │ match t1' with
> ┃ │ | trm_lam T j =>
> ┃ │ let free_vars := (FV_t j) ++ (FV_t t2') ++ (x::nil)
> ┃ │ in
> ┃ │ let y := pick_fresh free_vars in
> ┃ │ hsubst_t t2' y (T1,(open_t 0 (trm_fvar y) j))
> ┃ │ | _ => trm_app
> ┃ │ (hsubst_t s x (T,t1)) (hsubst_t s x (T,t2))
> end ↓ ⇓
> | _ => trm_app (hsubst_t s x (T,t1)) (hsubst_t s x (T,t2))
> end
> | (_,trm_c) => trm_c
> end.
All the pointed expressions can be factorised, thus reducing slightly
the number of required proofs, and the size of the term.
> I have a file which has everything in it here:
> http://homepage.cs.uiowa.edu/~heades/notes/Coq/hered_subst.v.
> Warning: it is an ugly file, but it all type checks. The function is
> at the bottom of the file.
> Is this the way I should be writing the program? I want to be
> able to define the above function, prove it correct, and then
> extract it to Ocaml. At the very least I would like to be able to
> actually compute with the thing.
> I need to be able to reason about this function. For example, this
> lemma
> Lemma hs_fvar : forall n, hsubst_t (trm_fvar n) n (typ_base, trm_fvar
> n) = trm_fvar n.
> is trivial and I can't seem to prove it. Even worse the subgoal is
> 1200 lines long!
> The issue is the fact that the termination argument is packaged up
> using sigma-types and interlaced into the program definition.
> My main question is, is this the right way to do this?
> Is there a better way?
> In my formalization I got around all of this by working in Prop. I
> defined the function as an inductive proposition and proved it
> functional. However, this cannot be computed with so I am not
> completely satisfied with that formalization. In addition not being
> able to do this has been bugging me so I thought I would ask the list.
> Thanks for any feedback.
> Harley
