coq-club - Re: [Coq-Club] Trouble reasoning about a well-founded program
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Harley D. Eades III <harley.eades AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Trouble reasoning about a well-founded program
  • Date: Fri, 14 Dec 2012 12:51:01 -0500
On 14 déc. 2012, at 10:33, Harley D. Eades III
wrote:
> Hello everyone.
> A while ago I formalized some of my research on the hereditary substitution
> function in Coq. At first I tried to define the function in Set using
> Program Fixpoint
> and the wf annotation. I was able to define the function and satisfy all
> the obligations.
> However, I can't compute with it. Even worse the subgoals generated are
> huge. They
> are over 1000 lines long.
<snip/>
> My main question is, is this the right way to do this?
> Is there a better way?
Hi Harley,
Yes, there is a better way:
You should define an unfolding lemma first to reason about the behavior of
the function.
Note that I added some [return _] to the inner matches where you didn't need
the equality
between the scrutiny and the pattern as well (makes for smaller generated
code).
Here's how to define it:
Program Definition hsubst_t_unfold (s:trm) (x:nat) (CUT:typ * trm) : trm :=
match CUT with
| (_,(trm_bvar x')) => (trm_bvar x')
| (_,(trm_fvar x')) => match (nat_compare x x') return _ with
| Eq => s
| _ => (trm_fvar x')
end
| (T,(trm_lam T' t1)) => trm_lam T' (hsubst_t s x (T,t1))
| (T,(trm_app t1 t2)) =>
match (ctype T x t1) with
| Some (typ_arrow T1 T2) =>
let t1' := hsubst_t s x (T,t1) in
let t2' := hsubst_t s x (T,t2) in
match t1' return _ with
| trm_lam T j =>
let free_vars := (FV_t j) ++ (FV_t t2') ++ (x::nil) in
let y := pick_fresh free_vars in
hsubst_t t2' y (T1,(open_t 0 (trm_fvar y) j))
| _ => trm_app (hsubst_t s x (T,t1)) (hsubst_t s x (T,t2))
end
end
| (_,trm_c) => trm_c
end.
(* Lemma fix_sub_eq_rect is there *)
Import WfExtensionality.
Lemma hsubst_t_unfold_eq s x cut : hsubst_t s x cut = hsubst_t_unfold s x cut.
Proof.
unfold hsubst_t.
(* Use setoid_rewrite to rewrite under the hsubst_t_func constant which
hides a Fix_sub *)
setoid_rewrite fix_sub_eq_ext.
reflexivity.
Qed.
(* Now you can reason on the unfolded version. *)
Lemma hs_fvar : forall n, hsubst_t (trm_fvar n) n (typ_base, trm_fvar n) =
trm_fvar n.
Proof.
intros. rewrite hsubst_t_unfold_eq. simpl. destruct (nat_compare n n);
reflexivity.
Qed.
Now for computing, you have to have a transparent [wf] proof, which currently
contains
a lot of opaque constants that reduction will get stuck at. Using the lexprod
construct
from the standard library and measures, you can define simply a fully
and should be able to solve the resulting obligations in much the same way
you did,
using mainly computation and a little bit of the theory of [lt] (only
transparent proofs
as well).
Require Import Relations Wellfounded.Wellfounded.
Definition order :=
lexprod typ (fun _ => trm) (MR lt typ_size) (fun _ => MR lt trm_size).
Lemma wf :
well_founded order.
Proof.
apply wf_lexprod. apply measure_wf. apply lt_wf. intro; apply measure_wf.
apply lt_wf.
Defined.
Definition order' (x y : typ * trm) :=
let x' : { _ : typ & trm } := existT _ (fst x) (snd x) in
let y' : { _ : typ & trm } := existT _ (fst y) (snd y) in
order x' y'.
(* Dep to non dep sums ordering *)
Lemma wf' :
well_founded order'.
Proof.
unfold well_founded.
destruct a as [ty tr].
remember (existT (fun _ => trm) ty tr) as arg.
assert (acc:=wf arg). revert ty tr Heqarg.
induction acc. intros. subst x.
constructor; intros.
destruct y. eapply H0.
apply H1. reflexivity.
Defined.
Hope this helps,
-- Matthieu
