- From: "Harley D. Eades III" <harley.eades AT gmail.com>
- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Trouble reasoning about a well-founded program
- Date: Mon, 17 Dec 2012 21:44:53 -0600
Hi, Auger.
Thanks a lot for your detailed response.
You explanations have helped a lot!
Thanks,
Harley
On Dec 15, 2012, at 4:50 AM, AUGER Cédric
wrote:
> Le Sat, 15 Dec 2012 00:41:56 +0100,
> AUGER Cédric
> a écrit :
> Sorry, it seems my file exceeded the size limit.
> See www.sedrikov.fr/hered_subst.v to retrieve the file.
>> Le Fri, 14 Dec 2012 11:57:35 -0600,
>> a écrit :
>>> Hi, Adam.
>>> On Dec 14, 2012, at 10:41 AM, Adam Chlipala
>>> <adamc AT csail.mit.edu>
>>> wrote:
>>>> On 12/14/2012 10:33 AM, Harley D. Eades III wrote:
>>>>> A while ago I formalized some of my research on the hereditary
>>>>> substitution function in Coq. At first I tried to define the
>>>>> function in Set using Program Fixpoint and the wf annotation. I
>>>>> was able to define the function and satisfy all the obligations.
>>>>> However, I can't compute with it. Even worse the subgoals
>>>>> generated are huge. They are over 1000 lines long.
>>>> Chapter 7 of CPDT <http://adam.chlipala.net/cpdt/> may be of
>>>> interest. It surveys a variety of techniques for general
>>>> recursion in Coq (not including Program, which I've never gotten
>>>> into, partly because of the issues you mention).
>>> Thanks for a lot for your feedback.
>>> I take a look at Chap. 7.
>>> Harley
>> I rewrote some parts of your file here. I won't enumerata all
>> differences, use a tool like 'diff' to get them all.
>> Some of my modifications may simplify parts of your proofs, I did not
>> inspect all.
>> Some general points:
>> → when defining an inductive, take care of indices vs parameters.
>> You can always make all indices, but that will make proofs harder to
>> do.
>> Inductive eq : ∀ (A : Type), A → A → Prop :=
>> | eq_refl : ∀ A x, eq A x x.
>> and
>> Inductive eq (A : Type) (x : A) : A → Prop :=
>> | eq_refl : eq A x x.
>> Are "almost" the same stuff (in fact you can show that these
>> definitions are equivalent). First definition uses indices only and
>> is harder to use than second definition. It is not too much annoying
>> when there is no recursion, but when recursion is involved, it can
>> be really painful, as you need to generalize correctly all variables.
>> → When using induction with "Acc" predicate, you need a proof of
>> "∀ x, Acc R x" (in your case, your "lex_wf" lemma). But to correctly
>> reduce it, you need parts of this proof to be transparent. That is
>> why your application didn't reduced. The part involving the proofs
>> themselves and not the recursion can (should) be abstracted to avoid
>> pollution.
- [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Adam Chlipala, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/14/2012
- Message not available
- Re: [Coq-Club] Trouble reasoning about a well-founded program, AUGER Cédric, 12/15/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/18/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Matthieu Sozeau, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, AUGER Cédric, 12/14/2012
