- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: "Harley D. Eades III" <harley.eades AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Trouble reasoning about a well-founded program
- Date: Sat, 15 Dec 2012 11:50:43 +0100
Le Sat, 15 Dec 2012 00:41:56 +0100,
AUGER Cédric
a écrit :
Sorry, it seems my file exceeded the size limit.
See www.sedrikov.fr/hered_subst.v to retrieve the file.
> Le Fri, 14 Dec 2012 11:57:35 -0600,
> a écrit :
> > Hi, Adam.
> > On Dec 14, 2012, at 10:41 AM, Adam Chlipala
> > <adamc AT csail.mit.edu>
> > wrote:
> > > On 12/14/2012 10:33 AM, Harley D. Eades III wrote:
> > >> A while ago I formalized some of my research on the hereditary
> > >> substitution function in Coq. At first I tried to define the
> > >> function in Set using Program Fixpoint and the wf annotation. I
> > >> was able to define the function and satisfy all the obligations.
> > >> However, I can't compute with it. Even worse the subgoals
> > >> generated are huge. They are over 1000 lines long.
> > > Chapter 7 of CPDT <http://adam.chlipala.net/cpdt/> may be of
> > > interest. It surveys a variety of techniques for general
> > > recursion in Coq (not including Program, which I've never gotten
> > > into, partly because of the issues you mention).
> > Thanks for a lot for your feedback.
> > I take a look at Chap. 7.
> > Harley
> I rewrote some parts of your file here. I won't enumerata all
> differences, use a tool like 'diff' to get them all.
> Some of my modifications may simplify parts of your proofs, I did not
> inspect all.
> Some general points:
> → when defining an inductive, take care of indices vs parameters.
> You can always make all indices, but that will make proofs harder to
> do.
> Inductive eq : ∀ (A : Type), A → A → Prop :=
> | eq_refl : ∀ A x, eq A x x.
> and
> Inductive eq (A : Type) (x : A) : A → Prop :=
> | eq_refl : eq A x x.
> Are "almost" the same stuff (in fact you can show that these
> definitions are equivalent). First definition uses indices only and
> is harder to use than second definition. It is not too much annoying
> when there is no recursion, but when recursion is involved, it can
> be really painful, as you need to generalize correctly all variables.
> → When using induction with "Acc" predicate, you need a proof of
> "∀ x, Acc R x" (in your case, your "lex_wf" lemma). But to correctly
> reduce it, you need parts of this proof to be transparent. That is
> why your application didn't reduced. The part involving the proofs
> themselves and not the recursion can (should) be abstracted to avoid
> pollution.
- [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Adam Chlipala, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/14/2012
- Message not available
- Re: [Coq-Club] Trouble reasoning about a well-founded program, AUGER Cédric, 12/15/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/18/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Matthieu Sozeau, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, AUGER Cédric, 12/14/2012
