- From: "Harley D. Eades III" <harley.eades AT gmail.com>
- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Trouble reasoning about a well-founded program
- Date: Fri, 14 Dec 2012 12:00:56 -0600
Hi, Matthieu.
On Dec 14, 2012, at 11:51 AM, Matthieu Sozeau
wrote:
> On 14 déc. 2012, at 10:33, Harley D. Eades III
> wrote:
>> Hello everyone.
>> A while ago I formalized some of my research on the hereditary substitution
>> function in Coq. At first I tried to define the function in Set using
>> Program Fixpoint
>> and the wf annotation. I was able to define the function and satisfy all
>> the obligations.
>> However, I can't compute with it. Even worse the subgoals generated are
>> huge. They
>> are over 1000 lines long.
> <snip/>
>> My main question is, is this the right way to do this?
>> Is there a better way?
> Hi Harley,
> Yes, there is a better way:
> You should define an unfolding lemma first to reason about the behavior of
> the function.
> Note that I added some [return _] to the inner matches where you didn't
> need the equality
> between the scrutiny and the pattern as well (makes for smaller generated
> code).
> Here's how to define it:
Thank you so much for this very detailed response. It helps a lot!
I am going to play around with this later this weekend!
I think you may have helped revive my original formalization. :-)
Thanks,
Harley
> Program Definition hsubst_t_unfold (s:trm) (x:nat) (CUT:typ * trm) : trm :=
> match CUT with
> | (_,(trm_bvar x')) => (trm_bvar x')
> | (_,(trm_fvar x')) => match (nat_compare x x') return _ with
> | Eq => s
> | _ => (trm_fvar x')
> end
> | (T,(trm_lam T' t1)) => trm_lam T' (hsubst_t s x (T,t1))
> | (T,(trm_app t1 t2)) =>
> match (ctype T x t1) with
> | Some (typ_arrow T1 T2) =>
> let t1' := hsubst_t s x (T,t1) in
> let t2' := hsubst_t s x (T,t2) in
> match t1' return _ with
> | trm_lam T j =>
> let free_vars := (FV_t j) ++ (FV_t t2') ++ (x::nil) in
> let y := pick_fresh free_vars in
> hsubst_t t2' y (T1,(open_t 0 (trm_fvar y) j))
> | _ => trm_app (hsubst_t s x (T,t1)) (hsubst_t s x (T,t2))
> end
> end
> | (_,trm_c) => trm_c
> end.
> (* Lemma fix_sub_eq_rect is there *)
> Import WfExtensionality.
> Lemma hsubst_t_unfold_eq s x cut : hsubst_t s x cut = hsubst_t_unfold s x
> cut.
> Proof.
> unfold hsubst_t.
> (* Use setoid_rewrite to rewrite under the hsubst_t_func constant which
> hides a Fix_sub *)
> setoid_rewrite fix_sub_eq_ext.
> reflexivity.
> Qed.
> (* Now you can reason on the unfolded version. *)
> Lemma hs_fvar : forall n, hsubst_t (trm_fvar n) n (typ_base, trm_fvar n) =
> trm_fvar n.
> Proof.
> intros. rewrite hsubst_t_unfold_eq. simpl. destruct (nat_compare n n);
> reflexivity.
> Qed.
> Now for computing, you have to have a transparent [wf] proof, which
> currently contains
> a lot of opaque constants that reduction will get stuck at. Using the
> lexprod construct
> from the standard library and measures, you can define simply a fully
> and should be able to solve the resulting obligations in much the same way
> you did,
> using mainly computation and a little bit of the theory of [lt] (only
> transparent proofs
> as well).
> Require Import Relations Wellfounded.Wellfounded.
> Definition order :=
> lexprod typ (fun _ => trm) (MR lt typ_size) (fun _ => MR lt trm_size).
> Lemma wf :
> well_founded order.
> Proof.
> apply wf_lexprod. apply measure_wf. apply lt_wf. intro; apply measure_wf.
> apply lt_wf.
> Defined.
> Definition order' (x y : typ * trm) :=
> let x' : { _ : typ & trm } := existT _ (fst x) (snd x) in
> let y' : { _ : typ & trm } := existT _ (fst y) (snd y) in
> order x' y'.
> (* Dep to non dep sums ordering *)
> Lemma wf' :
> well_founded order'.
> Proof.
> unfold well_founded.
> destruct a as [ty tr].
> remember (existT (fun _ => trm) ty tr) as arg.
> assert (acc:=wf arg). revert ty tr Heqarg.
> induction acc. intros. subst x.
> constructor; intros.
> destruct y. eapply H0.
> apply H1. reflexivity.
> Defined.
> Hope this helps,
> -- Matthieu
- [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Adam Chlipala, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/14/2012
- Message not available
- Re: [Coq-Club] Trouble reasoning about a well-founded program, AUGER Cédric, 12/15/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Harley D. Eades III, 12/18/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, Matthieu Sozeau, 12/14/2012
- Re: [Coq-Club] Trouble reasoning about a well-founded program, AUGER Cédric, 12/14/2012
