coq-club - Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • To: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
  • Cc: Maxime Dénès <mail AT maximedenes.fr>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • Date: Fri, 13 Dec 2013 13:07:47 +0000
Tr is not a recursive subterm of u here. The initial exemple relies on the fact that there is no recursive subterm to consider, ie the condition is vacuously true.
Le vendredi 13 décembre 2013, Jacques-Henri Jourdan a écrit :
I tried to adapt this example to find an example were there is no need to match over False. However, the guard conditions forbids me:
 Inductive True2 : Prop :=
   I2 : True -> True2.
 Hypothesis Heq : True = True2.
 Fixpoint contradiction (u : True2) : False :=
   match u with I2 Tr =>
      contradiction (match Heq in (_ = T) return T with eq_refl => Tr end)
   end.
So, what happens in this case ? Does this check be extended to make Coq reject the other construction ?
JH Jourdan
----- Mail original -----
> De: "Maxime Dénès" <mail AT maximedenes.fr>
> À: coq-club AT inria.fr
> Envoyé: Jeudi 12 Décembre 2013 22:41:18
> Objet: [Coq-Club] Propositional extensionality is inconsistent in Coq
> Hi folks,
> Arthur and I refined Daniel's example to show that Propositional
> Extensionality (even the weaker version of it) as defined in Coq's
> standard library is inconsistent in Coq's current theory:
> Require Import ClassicalFacts.
> Section func_unit_discr.
> Hypothesis Heq : (False -> False) = True.
> Fixpoint contradiction (u : True) : False :=
> contradiction (
>          | eq_refl => fun f:False => match f with end
>          end
> End func_unit_discr.
> Lemma foo : provable_prop_extensionality -> False.
> Proof.
> intro; apply contradiction.
> apply H.
> trivial.
> trivial.
> Qed.
> Print Assumptions foo.
> Print provable_prop_extensionality.
> (Typechecked with Coq 8.4pl2).
> Was that fact known?
> Maxime.
-- Matthieu
