coq-club - Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
  • To: Maxime Dénès <mail AT maximedenes.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Propositional extensionality is inconsistent in Coq
  • Date: Sat, 14 Dec 2013 19:36:58 +0100 (CET)
Note that we can build a similar contradiction without using a pattern
matching with no branches :
Require Import ClassicalFacts.
Inductive True1 : Prop := I1 : True1
with True2 : Prop := I2 : True1 -> True2.
Section func_unit_discr.
Hypothesis Heq : True1 = True2.
Fixpoint contradiction (u : True2) : False :=
contradiction (
match u with
| I2 Tr =>
match Heq in (_ = T) return T with
| eq_refl => Tr
end
end).
End func_unit_discr.
Lemma foo : provable_prop_extensionality -> False.
Proof.
intro; apply contradiction.
etransitivity. apply H. constructor.
symmetry. apply H. constructor. constructor.
Qed.
I am not sure I have understood the tentative fix of Christine Paulin, but it
seems like this would not solve this case either (True1 and True2 are in the
same inductive definition.
JH
----- Mail original -----
> De: "Maxime Dénès"
> À:
> Envoyé: Jeudi 12 Décembre 2013 22:41:18
> Objet: [Coq-Club] Propositional extensionality is inconsistent in Coq
> Hi folks,
> Arthur and I refined Daniel's example to show that Propositional
> Extensionality (even the weaker version of it) as defined in Coq's
> standard library is inconsistent in Coq's current theory:
> Hypothesis Heq : (False -> False) = True.
> Fixpoint contradiction (u : True) : False :=
> contradiction (
> | eq_refl => fun f:False => match f with end
> end
> Proof.
> apply H.
> trivial.
> trivial.
> Qed.
> Print Assumptions foo.
> Print provable_prop_extensionality.
> (Typechecked with Coq 8.4pl2).
> Was that fact known?
> Maxime.
