- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Fri, 25 Jul 2014 15:34:05 +0100
On Fri, Jul 25, 2014 at 3:10 PM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
I agree. I meant I was not sure how to implement this very feature. You can indeed make a bug report, it will help if the solution is not found quickly.
On 25 July 2014 15:41, Jason Gross <jasongross9 AT gmail.com> wrote:It might be nice, in general, if binders respected fresh. For example,On Fri, Jul 25, 2014 at 12:55 PM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
Also, by the way, is it intended that you have to inspect the hypotheses to get your hands on the name of the evar introduced by [refine (let e : T := _ in _)] in the second goal? That is, to get a fresh named evar as a goal, I do something likeLtac new_style_evar e T :=refine (let e' : T := _ in _);[| let e' := match goal with e' := _ |- _ => constr:(e') end inrename e' into e ].You are right that this is a problem. I'm not sure how to solve that. I'll look into it soon.Goal True.Proof.let H := fresh "E" inpose (fun H : Set => H).should give me [fun E : Set => E], not [fun H : Set => H]. I think this would be enough to solve the problem. Should I make a bug report?
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), (continued)
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/25/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/25/2014
