- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Fri, 25 Jul 2014 08:36:34 +0200
Can one transform an existing evar into such a thing? Or only those introduced by refine?
I don't have a good method to transform otherwise introduced existential variables into goals at the moment. Either they were introduced by a refine, or you can use the Grab Existential Variables command when no goal is left to turn all the remaining existential variables into goals.
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), (continued)
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/25/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/25/2014
