- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Fri, 25 Jul 2014 11:31:41 +0100
Is the problem the syntax, or the code? You can already write a [solve evar e using tac] by throwing [tac] into [$(...)$], and then unifying [e] with the result. If it's the syntax, how about [unshelve e], which leaves you with one additional focused goal at the front?
Also, by the way, is it intended that you have to inspect the hypotheses to get your hands on the name of the evar introduced by [refine (let e : T := _ in _)] in the second goal? That is, to get a fresh named evar as a goal, I do something like
Ltac new_style_evar e T :=
refine (let e' : T := _ in _);
| let e' := match goal with e' := _ |- _ => constr:(e') end in
rename e' into e ].
On Fri, Jul 25, 2014 at 7:36 AM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
Can one transform an existing evar into such a thing? Or only those introduced by refine?
I don't have a good method to transform otherwise introduced existential variables into goals at the moment. Either they were introduced by a refine, or you can use the Grab Existential Variables command when no goal is left to turn all the remaining existential variables into goals.
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), (continued)
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/25/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/25/2014
