- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
- Date: Thu, 24 Jul 2014 19:38:11 +0100
proof_admitted is just a proof of [False] that is used to implement the [admit] tactic. You can only use it to get around "Instance is not well-typed" when your instance came from [admit]; in this case, you're essentially just running [admit] again.
On Thu, Jul 24, 2014 at 7:35 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 07/24/2014 02:06 PM, Jonathan wrote:Trying this out:
However, I guess the criticism here is that this is the all-to-common (for me, at least) case of needing to fill in an existential when it's too late to do so (getting the "Instance is not well-typed in the environment of" error) - and instead (hopefully) knowing in advance what to do to set up for a successful instantiation.
Goal exists n, n=0.(*normally, it would be too late to fill in that evar with newly-introduces things, like:*)
refine (ex_intro _ _ _).
assert {m:nat|m=0} as H by admit.
destruct H as [x H].
exact x. (*No "Instance is not well-typed" error! Cool!*)
But, what on earth is happening in that second subgoal?:
(fun H : {m : nat | m = 0} => let (x, _) := H in x)
match proof_admitted return {m : nat | m = 0} with
end = 0
Hmmm... let's try pushing the red button marked danger:
destruct proof_admitted.
Boom! It worked!
OK - so now I want to know more about this proof_admitted mumbo-jumbo. What is going on there? How can I use this to get around other cases of "Instance is not well-typed" related to lateness of instantiation?
-- Jonathan
- [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.)), (continued)
- [Coq-Club] nice evar tactics (was: Re: Prop smuggling (was: Re: Smart case analysis in Coq.)), Jonathan, 07/23/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jonathan, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/24/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Arnaud Spiwack, 07/25/2014
- Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.), Jason Gross, 07/25/2014
