coq-club - Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Prop smuggling (was: Re: Smart case analysis in Coq.)
  • Date: Thu, 24 Jul 2014 14:06:55 -0400
On 07/24/2014 12:51 PM, Jason Gross wrote:
They are useful because I can use tactics to solve them interactively. If
the interesting bit is the first subgoal, and the constraint is something
that should be solvable by some general tactic that isn't good enough to
fill in evars, then you can first construct your term, and then later prove
the laws. For example, this means that I can construct a category
interactively, rather than having to first construct the objects,
morphisms, composition, and identity, all in one go, and then only getting
to prove the laws interactively.
-Jason
OK - it's getting clearer, I think. Normally - before this special refine behavior - what one would do to change the current goal into a more preferred one would be to assert the preferred one. The assert then would give you a witness (hypothesis) in the second subgoal that you could use. However, the witness provided by assert is completely generic - untied to any you produced to solve the first subgoal - and so can't be used to solve arbitrary constraints that only specific instances could solve.
With refine, whatever witness you provide to solve the first subgoal is identically the one introduced in the second subgoal. So, one could then construct the category in the first subgoal along with some specific element, and use that element as the witness to the first subgoal, and get it to solve the second as well. With assert, you lose that ability. But, you have to be very careful to keep track of the constraints imposed by that second subgoal, unless they're trivially solvable as you say (but if they're too trivial, then assert would have worked just as well!) - although with evar backtracking, things might be a bit easier.
But, this is still confusing in certain ways. If I was going to solve such an exists goal by constructing a new category and using a specific element in it, I would do so before destructuring the exists goal, so that the category and all of its elements appear in both subgoals (when I eventually do the eexists).
However, I guess the criticism here is that this is the all-to-common (for me, at least) case of needing to fill in an existential when it's too late to do so (getting the "Instance is not well-typed in the environment of" error) - and instead (hopefully) knowing in advance what to do to set up for a successful instantiation. Reminds me of the old joke (often used to explain one-pass vs. two-pass algorithms) about giving directions to someone taking a bus: when the bus reaches the museum, your stop was the previous one.
If so - great - I appreciate any and all ways to get around the evil "Instance is not well-typed in the environment of" error. Although I do suspect that Coq's decisions on when an instance is well-typed are overly conservative, and not always uniform. For example, I have seen cases when using instantiate to fill in an evar with a particular instance produces the error, but using unify instead with the same evar and instance (in the very same goal) works.
-- Jonathan
