- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
- Date: Mon, 04 Aug 2014 09:18:23 +0200
On 04/08/2014 01:59, Jonathan wrote:
> It would certainly be nice if the rule was simply that
anything at all that contains no information can be case analyzed in any
context. I would even argue that things like "False \/ P" should be
case analyzable in any context - because (and, of course) it can be
turned into P by use of assert, applying a lemma or a rewrite.
How can you argue that a value of type "False \/ P" contains no information? There are two constructors! If we were to follow your line of thoughts, then, whatever the inductive type T, values of that type should be destructible in any context, because we are always able to create a function from T to True and values of type True are known to be destructible in any context.
The important point, both in your earlier example and in that "False \/ P" case, is that, as a user, you tell the system how to create a singleton and thus discard any information present in your original value.
If you are ever able to destruct a value that is not a singleton in order to create a value with a type in Set, then you will have found a major bug in Coq. But for now, Section "4.5.4 Destructors" of the manual still applies.
Best regards,
Guillaume
- Re: [Coq-Club] what exactly are the Prop analysis rules?, (continued)
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Pierre-Marie Pédrot, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Arnaud Spiwack, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Guillaume Melquiond, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Matthieu Sozeau, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Daniel Schepler, 08/05/2014
