- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
- Date: Mon, 04 Aug 2014 15:09:10 -0400
On 08/04/2014 02:10 PM, Maxime Dénès wrote:
I meant phi returns Props, not booleans (although the same works with bool).
On 08/04/2014 02:08 PM, Maxime Dénès wrote:
The main concern is not extraction, but proof irrelevance. If you allow unrestricted elimination from True \/ True, you can build the following function:
Definition phi (p : True \/ True) : bool :=
match p with
| or_introl _ => True
| or_intror _ => False
end
Then you can refute proof irrelevance: assume it, deduce or_introl I = or_intror I hence phi (or_introl I) = phi (or_intror I), hence True = False, hence False.
Ah - that's the example I needed to jar me out of this rut! Thanks, Maxime!
My naive view of rewrite rules as information preservation devices must be untrue in some way. But, what is the difference between those kinds of bits in Prop can be created/destroyed arbitrarily by rewrite rules vs. those that can't?
It is almost as though the bit in or is necessarily irrelevant (note: P \/ Q <-> Q \/ P), independent of the proof irrelevance axiom, where the others are contingently irrelevant based on inclusion or not of the proof irrelevance axiom. Or, "semi-contingently irrelevant" - with the proof irrelevance axiom, they are, but without it they merely "might be". But that "might be" is strong enough to prevent arbitrary creation/destruction due to rewrites.
Regardless, the case analysis rules have to prevent any and all irrelevant bits from becoming relevant.
-- Jonathan
- Re: [Coq-Club] what exactly are the Prop analysis rules?, (continued)
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Guillaume Melquiond, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Matthieu Sozeau, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Daniel Schepler, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cedric Auger, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Arnaud Spiwack, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Daniel Schepler, 08/06/2014
