- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
- Date: Mon, 04 Aug 2014 13:05:24 -0400
On 08/04/2014 01:02 PM, Guillaume Melquiond wrote:
On 04/08/2014 18:20, Jonathan wrote:
How can you argue that a value of type "False \/ P" contains no
information? There are two constructors!
I can have a rewrite rule "False \/ P <-> P", which of course is
reversible. I am under the impression that a rewrite, by being
reversible, demonstrates that the two sides contain the same
information. So, there must not be any extra information in the "False
\/" part, so to speak. Is that incorrect?
Yes. As already pointed out by Arnaud, True \/ True is equivalent to True, which is a singleton type, yet it is isomorphic to bool, which is definitely not a singleton type. So just knowing about an equivalence is not enough for deciding whether a type can be destructed.
Best regards,
Guillaume
True \/ True is not isomorphic to bool. Instead, the eerily similar {True} + {True} is isomorphic to bool. At least if I am properly understanding isomorphisms.
-- Jonathan
- Re: [Coq-Club] what exactly are the Prop analysis rules?, (continued)
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Jonathan, 08/03/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cédric, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Guillaume Melquiond, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Maxime Dénès, 08/04/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Matthieu Sozeau, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Daniel Schepler, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Cedric Auger, 08/05/2014
- Re: [Coq-Club] what exactly are the Prop analysis rules?, Arnaud Spiwack, 08/05/2014
