coq-club - Re: [Coq-Club] what exactly are the Prop analysis rules?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] what exactly are the Prop analysis rules?
  • Date: Mon, 04 Aug 2014 13:55:05 -0400
On 08/04/2014 01:19 PM, Maxime Dénès wrote:
Now, you were asking: is the answer to that question the same for proofs of two equivalent propositions. No, as Guillaume showed it : True and True \/ True are logically equivalent. Yet, if you allow to eliminate a proof of True to Set, you don't reveal anything, whereas allowing the same elimination from a proof of True \/ True reveals one bit of information. Relaxing the elimination restriction on True \/ True made it isomorphic to bool.
Maxime.
I am sorry for being slow here, but I still don't see any bit of information in True \/ True that could be revealed under any circumstance. Is my claim that having a rewrite rule True \/ True <-> True demonstrates that both sides have the same information content false? If so, I think we must be using the word "information" in different ways.
I guess if you are worried about extraction, and you allowed analysis of True \/ True in a non-Prop context, and the extractor wasn't sufficiently savvy (and as Arnaud points out, it has much more serious matters to attend to than this), then you would end up with two branches of a match statement, but have no way to cause the generated code to take one vs. the other - so one or the other is dead code, and the compiler just has to choose which it is. But, it shouldn't matter, because whichever branch it chooses would be identical to whatever you could have extracted without analyzing True \/ True.
-- Jonathan
