coq-club - [Coq-Club] an evar with a split personality
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] an evar with a split personality
  • Date: Wed, 03 Sep 2014 21:19:35 -0400
When experimenting with the evars, using a recent trunk version of Coq, I noticed the following:
Set Printing Existential Instances. (*Or, if in CoqIde, use View->Display existential variable instances*)
Require Setoid.
Goal forall a b:nat, a=b -> exists c:nat, c = c.
intros a b aeqb.
eexists. (*make an evar*)
match goal with |- ?V = ?V => remember V as e eqn:Q end. (*clone the evar*)
rewrite Q at 2. (*make the consequent and Q look really similar*)
rewrite aeqb. (*rewrite works! And the two evar contexts for the same "e" evar no longer match!*)
Fail exact Q. (*?*)
instantiate (1:=a) in Q. (*??*)
I don't know if this is a bug or a feature. I guess it could be a feature, but then it points out something quite unexpected: that a single evar can have multiple different contexts, even within the same goal. I was under the impression that all copies of the same evar shared the same single context.
If this is a bug - is the bug that "rewrite aeqb" does anything at all, or that it only rewrites one of the contexts?
If this is a feature:
Are all instances of an evar separable this way, or just some? Which ones?
What tactics other than rewrite can be used to modify a specific version of an evar's context without modifying the others? How does one target the context with a tactic?
-- Jonathan
