- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] an evar with a split personality
- Date: Fri, 12 Sep 2014 12:51:17 -0400
On 09/12/2014 12:47 PM, Jonathan wrote:
Well, having names for evars may be useful, but now Set Printing Existential Instances does absolutely nothing.
Also, some change is making [typeclasses eauto with core] loop where before it found a solution.
Maybe I git pulled to early?
With this evar naming scheme: I see that the refine-born evars are all ?GoalN for N being the current number of the corresponding evar subgoal. But, shelve_unifiable hides the evar subgoals (so one no longer sees the correspondence), and the cycle/swap/revgoal tactics also mess with the correspondence. Frankly, it was better when the evar ID and the subgoal ID corresponded. Might there be a way to name evars and their corresponding subgoals manually? An intro pattern associated with refine?
I'm also getting inundated with warnings of the form:
Warning: Invalid character '?' at beginning of identifier "?1158".
-- Jonathan
- [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Matthieu Sozeau, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Hugo Herbelin, 09/13/2014
