- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] an evar with a split personality
- Date: Fri, 12 Sep 2014 12:47:15 -0400
On 09/12/2014 11:43 AM, Jonathan wrote:
On 09/12/2014 11:38 AM, Jonathan wrote:
On 09/12/2014 08:29 AM, Arnaud Spiwack wrote:
Note that the order of hypotheses in the focused goal can't be used toSince this very morning. And thanks to Hugo Herbelin, the substitutions of
determine what is being substituted for, because of cases like:
existential variables are systematically printed (in fact, only the part
which is not the identity). The printed substitution tells you by name what
is substituted. This should help users figure how they work.
I just did a git pull and rebuild, but am not seeing any change. What should I be looking for?
-- Jonathan
Oh - my rebuild didn't fully rebuild. I need to redo it...
-- Jonathan
Well, having names for evars may be useful, but now Set Printing Existential Instances does absolutely nothing.
Also, some change is making [typeclasses eauto with core] loop where before it found a solution.
Maybe I git pulled to early?
With this evar naming scheme: I see that the refine-born evars are all ?GoalN for N being the current number of the corresponding evar subgoal. But, shelve_unifiable hides the evar subgoals (so one no longer sees the correspondence), and the cycle/swap/revgoal tactics also mess with the correspondence. Frankly, it was better when the evar ID and the subgoal ID corresponded. Might there be a way to name evars and their corresponding subgoals manually? An intro pattern associated with refine?
-- Jonathan
- [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Matthieu Sozeau, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Hugo Herbelin, 09/13/2014
