coq-club - Re: [Coq-Club] an evar with a split personality
  • From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] an evar with a split personality
  • Date: Fri, 12 Sep 2014 21:02:20 +0200
Hi Jonathan,
If you’re on the bleeding edge, you can expect to get hurt like this :)
I think it might be my doing, I made a change I’m not so sure of to
typeclasses eauto in the trunk. Please report this on coq-bugs or coq-dev
(https://sympa.inria.fr/sympa/info/coqdev) instead of here.
Best,
— Matthieu
On 12 sept. 2014, at 20:34, Jonathan
<jonikelee AT gmail.com>
wrote:
> On 09/12/2014 02:07 PM, Jonathan wrote:
>> On 09/12/2014 12:47 PM, Jonathan wrote:
>>> Also, some change is making [typeclasses eauto with core] loop where
>>> before it found a solution.
>> Preliminary analysis suggests that some recent change is causing more
>> instances of something like bug #3381, where usage of [typeclasses eauto
>> with core] can cause evars that aren't involved in the targeted subgoal to
>> get instantiated, blocking the solution of other subgoals.
>> Is it possible that [typeclasses eauto with core] doesn't properly undo
>> instantiations after failing (or giving up due to depth) along certain
>> search paths?
>> The change is between Sept 9 and today.
>> -- Jonathan
> There are also more cases of something like bug #3417: "Anomaly: Uncaught
> exception Not_found(_). Please report." when trying to setoid_rewrite under
> binders.
> -- Jonathan
