- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] an evar with a split personality
- Date: Fri, 12 Sep 2014 15:18:41 -0400
On 09/12/2014 03:02 PM, Matthieu Sozeau wrote:
Hi Jonathan,
If you’re on the bleeding edge, you can expect to get hurt like this :)
Certainly! I'm not complaining - things with regards to evars and automation are heading in the right direction (so far as I can tell, not having a roadmap) in the trunk - just not necessarily monotonically. I don't expect otherwise.
I also have little choice, as I've based so much already on the typeclasses eauto changes in the trunk, among other changes.
I think it might be my doing, I made a change I’m not so sure of to
typeclasses eauto in the trunk. Please report this on coq-bugs or coq-dev
(https://sympa.inria.fr/sympa/info/coqdev) instead of here.
Best,
— Matthieu
OK. I will (attempt to) use Jason's bug-narrowing scripts...
-- Jonathan
- Re: [Coq-Club] an evar with a split personality, (continued)
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/04/2014
- Re: [Coq-Club] an evar with a split personality, Arnaud Spiwack, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Jonathan, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Matthieu Sozeau, 09/12/2014
- Re: [Coq-Club] an evar with a split personality, Hugo Herbelin, 09/13/2014
