coq-club - Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • Date: Thu, 26 Mar 2015 11:40:34 -0400
On 03/26/2015 04:56 AM, Soegtrop, Michael wrote:
Dear Coq users
for guiding automation heuristics I sometimes need to classify terms. For
this I am missing an ltac function has_var, similar to has_evar. Is there a
way to implement this in ltac?
I am assuming you want has_var to spot only free vars. In which case it can be written in ltac as:
Ltac has_var term :=
match term with
context[?V] => is_var V
end.
Also I wonder if there is a good way to check if a term is a literal, in the
sense that it consists entirely of constructors, e.g. a literal number or
boolean value or more complex term, but without vars, evars, matches or
function applications. On a simplified term I guess checking not has_var and
not has_evar would work.
The difficulty would be in determining if the function head of a (sub)term is a constructor vs. another kind of function. It is possible, but very complicated to write a tactic that identifies the constructors of a type in Ltac - but there is also a plugin to do this, which is more recommended.
Another useful thing would be an ltac function, which evaluates some sort of
complexity measure of a term. I have some idea how this could be done, but
before I try it, I wanted to ask if someone has something ready I could use.
I would think this must be already done as part of some plugin or extension, although maybe not with the same complexity measure you are looking for.
-- Jonathan
