coq-club - Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • Date: Thu, 26 Mar 2015 17:08:15 -0400
On 03/26/2015 04:43 PM, Jonathan Leivent wrote:
On 03/26/2015 04:34 PM, Jonathan Leivent wrote:
On 03/26/2015 04:28 PM, Jason Gross wrote:
On Thu, Mar 26, 2015 at 4:18 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On second thought, it isn't very hard to write an Ltac "is_ctor" tactic.
This way might not even be considered too kludgey:
Nice tactic!
But it doesn't work on sufficiently dependent types; [is_ctor @eq_refl]
fails with an "illegal application" error.
Oops - that's because destruct isn't a universal tactic for inductive types. Maybe I can use case_eq instead? Unless that also has issues with some inductive types...
-- Jonathan
Actually meant to say "[destruct eqn:] isn't a universal tactic". Is that a bug?
Anyway, here's a version with case_eq:
Ltac is_ctor sym :=
let h:=fresh in
let E:=fresh in
let A:=fresh in
let t:=type of sym in
let m:=constr:($(clear; intros A h; repeat specialize (h $(apply A)$);
case_eq h; intro E;
match type of E with _ = ?C =>
let c:=head_of C in exact (any c)
end)$ : (forall T, T) -> t -> Any) in
match m with
context[any sym] => idtac
end.
It works for @eq_refl - but that doesn't mean there isn't something out there that will confuse it.
-- Jonathan
Well, case_eq has its own issues, doesn't it? I looked at what case_eq generated as the equality in the @eq_refl case - and it was "eq_refl = eq_refl". Which may be a bug, I guess - as it should probably be "H=eq_refl" for case_eq H.
OK, so let's not depend on either the "eqn:" version of destruct or the "_eq" version of case - and use just vanilla destruct - which hopefully is used often enough that it doesn't have goofy behavior even in unusual cases:
Inductive Any2{T}(x:T) : Prop := any2.
Ltac is_ctor sym :=
let h:=fresh in
let E:=fresh in
let A:=fresh in
pose (any2 h) as E;
destruct h;
match type of E with Any2 ?C =>
match m with
end.
-- Jonathan
