coq-club - Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • Date: Thu, 26 Mar 2015 22:35:57 -0400
Here's a somewhat dressed-up version of is_ctor that should run even in pre-8.5 versions of Coq (no tactic-in-term). The ugly control flow ("fail flailing") due to the absence of tryif is unfortunate, though.
Ltac head_of term :=
lazymatch term with
| (?H _) => head_of H
| _ => term
end.
Ltac get_value H := eval cbv delta [H] in H.
Ltac is_ctor sym :=
let H:=fresh in
let H2:=fresh in
let A:=fresh in
try
(try
(assert ((forall T, T) -> True) by
(intro A;
first [pose sym as H | fail 3 "is_ctor:" sym "is not a valid term"];
repeat specialize (H (A _));
pose H as H2;
first [destruct H | fail 3 "is_ctor:" sym "does not produce an inductive type"];
let C:=get_value H2 in
let c:=head_of C in
try (constr_eq c sym; fail 2 (*success*));
exact I);
fail 2 "is_ctor:" sym "is not a constructor");
fail 1 "is_ctor - problem with tactic").
Variable F:nat.
Variable T:Type.
Variable G:T.
Goal True.
Fail is_ctor F.
Fail is_ctor G.
Fail is_ctor X.
is_ctor 0.
Fail is_ctor 1.
is_ctor S.
is_ctor cons.
is_ctor @nil.
is_ctor @eq_refl.
is_ctor true.
is_ctor false.
is_ctor I.
Fail is_ctor (cons 1 nil).
Fail is_ctor True.
Fail is_ctor Type.
exact I.
Qed.
-- Jonathan
