Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- Date: Thu, 26 Mar 2015 16:18:14 -0400
On 03/26/2015 11:40 AM, Jonathan Leivent wrote:
On 03/26/2015 04:56 AM, Soegtrop, Michael wrote:
Also I wonder if there is a good way to check if a term is a literal, in the sense that it consists entirely of constructors, e.g. a literal number or boolean value or more complex term, but without vars, evars, matches or function applications. On a simplified term I guess checking not has_var and not has_evar would work.
The difficulty would be in determining if the function head of a (sub)term is a constructor vs. another kind of function. It is possible, but very complicated to write a tactic that identifies the constructors of a type in Ltac - but there is also a plugin to do this, which is more recommended.
On second thought, it isn't very hard to write an Ltac "is_ctor" tactic. This way might not even be considered too kludgey:
Inductive Any : Prop :=
| any{T}(x:T) : Any. (*a simple holder for anything*)
Ltac head_of term :=
lazymatch term with
| (?H _) => head_of H
| _ => term
end.
Ltac is_ctor sym :=
let h:=fresh in
let E:=fresh in
let A:=fresh in
let t:=type of sym in
let m:=constr:($(clear; intros A h; repeat specialize (h $(apply A)$);
destruct h eqn:E;
match type of E with _ = ?C =>
let c:=head_of C in exact (any c)
end)$ : (forall T, T) -> t -> Any) in
match m with
context[any sym] => idtac
end.
Variable F : nat.
Goal True.
is_ctor 0.
is_ctor cons.
is_ctor @nil.
is_ctor S.
Fail is_ctor 1.
Fail is_ctor F.
Abort.
-- Jonathan
- [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jason Gross, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/27/2015
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 03/31/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/31/2015
