Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- Date: Thu, 26 Mar 2015 16:34:55 -0400
On 03/26/2015 04:28 PM, Jason Gross wrote:
On Thu, Mar 26, 2015 at 4:18 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On second thought, it isn't very hard to write an Ltac "is_ctor" tactic.
This way might not even be considered too kludgey:
Nice tactic!
But it doesn't work on sufficiently dependent types; [is_ctor @eq_refl]
fails with an "illegal application" error.
Oops - that's because destruct isn't a universal tactic for inductive types. Maybe I can use case_eq instead? Unless that also has issues with some inductive types...
-- Jonathan
- [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jason Gross, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/27/2015
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 03/31/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/31/2015
