Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- Date: Tue, 31 Mar 2015 11:09:00 -0400
On 03/31/2015 04:04 AM, Soegtrop, Michael wrote:
Dear Jonathan,
thanks a lot for your elaborate answer! I am still digesting it. I am
experimenting if it works better for my automation control to detect terms
which contain only constructors using the method you described or to detect
terms which contain something which is not a constructor. The first is more
directly what I want. The other might be more efficient, but as I said I am
still experimenting.
Thanks & best regards,
Michael
I am not sure how one would determine that a term contains something which is not a constructor without examining each function symbol to see whether or not it is a constructor symbol. Do you have an idea how to do this, or are you searching for such an idea?
By the way, I was able to create a ctors tactic based on that is_ctor tactic which returns all of the constructor symbols for an inductive type without requiring much more complexity or kludges - even a version that works in versions of Coq prior to 8.5 - meaning without tactic-in-term. I had previously thought it would be much more complex and/or kludgey to do this without a plugin, and not even possible prior to 8.5. If anyone wants this, I can post it.
Another point that occurred to me about your goal of an Ltac tactic that produces a complexity measure for a term - I think one area where this could get very complicated is when analyzing terms that contain match expressions. Unless it is OK for your purposes to not bother to analyze the branches within a match expression. I am not saying it is impossible, it just seems like it would be quite difficult.
-- Jonathan
- [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jason Gross, 03/26/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/27/2015
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 03/31/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 03/31/2015
