- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] CoqIDE loadpath error for ssreflect
- Date: Thu, 11 Jun 2015 10:47:27 +0100
To load at the Terminal I use: coqtop
To run CoqIDE I click on the icon in the Application Folder ( I installed it using coqude-8.4p15.dmg ).
On Thu, Jun 11, 2015 at 10:38 AM, Pierre Courtieu <pierre.courtieu AT gmail.com> wrote:
Can you give the exact way you launch coqtop (terminal) and coqide please? You should somehow set the same loadpath options for both.P.2015-06-11 11:27 GMT+02:00 David Black <dtinblack AT gmail.com>:Hi Pierre,Thanks for the suggestion which I tried but unfortunately I get the error: Cannot find library Ssreflect.ssreflect in loadpath.Kind regards,DavidOn Thu, Jun 11, 2015 at 10:17 AM, Pierre Courtieu <pierre.courtieu AT gmail.com> wrote:Hi, welcome to Coq.Have you just tried "Require Import Ssreflect.ssreflect." ?Best regards,Pierre2015-06-11 11:12 GMT+02:00 David Black <dtinblack AT gmail.com>:Hello,
I am a Coq newbie and therefore to improve my understanding of proof checking I am trying to use the Ssreflect library.
I have installed Ssreflect v 1.5 on a Mac OS v 10.10.3 ( Yosemite ) which runs at the Terminal.
However when I tried to load the library into CoqIDE 8.4p15 using: Require Import ssreflect.
I get the error: Cannot find library ssreflect in loadpath
I have tried using: Add LoadPath "/opt/local/lib/coq/user-contrib/Ssreflect/".
where SSRCOQ_LIB is currently set,but I get the error: The file /opt/local/lib/coq/user-contrib/Ssreflect/ssreflect.vo contains library Ssreflect.ssreflect and not library ssreflect
Grateful for any help in loading the ssreflect library from within CoqIDE.
Kind regards,
David Black
- [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Courtieu, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Wilke, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Enrico Tassi, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Boutillier, 06/12/2015
