coq-club - Re: [Coq-Club] CoqIDE loadpath error for ssreflect
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] CoqIDE loadpath error for ssreflect
  • Date: Fri, 12 Jun 2015 11:42:53 +0100
Hi Ralf,
Apologies for not following your instructions. It looks as though it has found the file.
However I now have the following error: Compiled library Ssreflect.ssreflect.vo makes inconsistent assumptions
over library Coq.Init.Notations
Interestingly I copied the ssreflect related files to a new folder and from the command line in the Terminal ( I am using coqtop version 8.4pl5 ) and followed your instructions and it loaded the file without any errors. Is CoqIDE automatically loading a different version of Notations than coqtop ? Is there anyway of checking ? Or is it a different problem that is causing the error ?
Kind regards,
David
On Fri, Jun 12, 2015 at 10:59 AM, Ralf Jung <jung AT mpi-sws.org> wrote:
Hi,
> I used the following instructions in CoqIDE:
> Add LoadPath "/opt/local/lib/coq/user-contrib/Ssreflect/".
That's not what I suggested should work ;-)
Quoting from my first mail:
Add LoadPath "/opt/local/lib/coq/user-contrib/".
> Require Import Ssreflect.ssreflect.
Coq concatenates the paths: if you tell it to look in
"/opt/local/lib/coq/user-contrib/", and it looks for
Ssreflect.ssreflect, the "." becomes a "/" and a ".vo" is added. That's
the file it looks for.
The alternative would be to add "Ssreflect" to the Path *and* *not* do
the "Require", but you said that's what you tried first, and it did not
work.
Kind regards,
Ralf
