- To: coq-club AT inria.fr
- Cc: David Black <dtinblack AT gmail.com>
- Subject: Re: [Coq-Club] CoqIDE loadpath error for ssreflect
- Date: Thu, 11 Jun 2015 11:53:47 +0200
Hello,
Have you tried the following?
Add LoadPath "path/to/ssreflect" as Ssreflect.
It solves the same kind of problem for me (not with Ssreflect, though).
Pierre
On 06/11/2015 11:47 AM, David Black
wrote:
To load at the Terminal I use: coqtop
To run CoqIDE I click on the icon in the Application Folder
( I installed it using coqude-8.4p15.dmg ).
On Thu, Jun 11, 2015 at 10:38 AM,
Pierre Courtieu <pierre.courtieu AT gmail.com>
wrote:
Can you give the exact way you launch coqtop
(terminal) and coqide please? You should somehow set the
same loadpath options for both.
P.
2015-06-11 11:27 GMT+02:00
David Black <dtinblack AT gmail.com>:
Hi Pierre,
Thanks for the suggestion which I tried but
unfortunately I get the error: Cannot find
library Ssreflect.ssreflect in loadpath.
Kind regards,
David
On Thu, Jun 11,
2015 at 10:17 AM, Pierre Courtieu <pierre.courtieu AT gmail.com>
wrote:
Hi, welcome to Coq.
Have you just tried "Require
Import Ssreflect.ssreflect." ?
Best regards,
Pierre
2015-06-11
11:12 GMT+02:00 David Black <dtinblack AT gmail.com>:
Hello,
I
am a Coq newbie and
therefore to improve my
understanding of proof
checking I am trying to
use the Ssreflect library.
I
have installed Ssreflect v
1.5 on a Mac OS v 10.10.3
( Yosemite ) which runs at
the Terminal.
However
when I tried to load the
library into CoqIDE 8.4p15
using: Require Import
ssreflect.
I
library ssreflect in
loadpath
I
have tried using: Add
LoadPath
"/opt/local/lib/coq/user-contrib/Ssreflect/".
where
SSRCOQ_LIB is currently
set,
but
I get the error: The
file
/opt/local/lib/coq/user-contrib/Ssreflect/ssreflect.vo
contains library
Ssreflect.ssreflect and
not library ssreflect
Grateful
for any help in loading
the ssreflect library
from within CoqIDE.
Kind
regards,
David
Black
- [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Courtieu, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Wilke, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Enrico Tassi, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Boutillier, 06/12/2015
