- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] CoqIDE loadpath error for ssreflect
- Date: Fri, 12 Jun 2015 11:59:59 +0200
Hi,
> I used the following instructions in CoqIDE:
> Add LoadPath "/opt/local/lib/coq/user-contrib/Ssreflect/".
That's not what I suggested should work ;-)
Quoting from my first mail:
Add LoadPath "/opt/local/lib/coq/user-contrib/".
> Require Import Ssreflect.ssreflect.
Coq concatenates the paths: if you tell it to look in
"/opt/local/lib/coq/user-contrib/", and it looks for
Ssreflect.ssreflect, the "." becomes a "/" and a ".vo" is added. That's
the file it looks for.
The alternative would be to add "Ssreflect" to the Path *and* *not* do
the "Require", but you said that's what you tried first, and it did not
work.
Kind regards,
Ralf
- [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Courtieu, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Wilke, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Enrico Tassi, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Boutillier, 06/12/2015
