- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] CoqIDE loadpath error for ssreflect
- Date: Fri, 12 Jun 2015 13:44:59 +0200
On Fri, Jun 12, 2015 at 11:42:53AM +0100, David Black wrote:
> Hi Ralf,
> Apologies for not following your instructions. It looks as though it has
> found the file.
> However I now have the following error: Compiled library
> Ssreflect.ssreflect.vo makes inconsistent assumptions
> over library Coq.Init.Notations
> Interestingly I copied the ssreflect related files to a new folder and from
> the command line in the Terminal ( I am using coqtop version 8.4pl5 ) and
> followed your instructions and it loaded the file without any errors. Is
> CoqIDE automatically loading a different version of Notations than coqtop ?
CoqIDE adds the current directory (or the directory containing the file
you opened with it). It also reads extra flags from files named like
_CoqProject (by default, you can actually configure the name).
So yes, CoqIDE may add paths to the LoadPath, and I guess they contain
an old/different copy of Notation.vo
Best,
Enrico Tassi
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, (continued)
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Courtieu, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Wilke, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/11/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, David Black, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Ralf Jung, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Enrico Tassi, 06/12/2015
- Re: [Coq-Club] CoqIDE loadpath error for ssreflect, Pierre Boutillier, 06/12/2015
