coq-club - Re: [Coq-Club] question about universes and equalities
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 18:22:15 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:QmDBKx+ZMtlEVf9uRHKM819IXTAuvvDOBiVQ1KB91+8cTK2v8tzYMVDF4r011RmSDdSdsqkP07uempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lS8iL1I/vhqibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEzoSYqK630AZV0Xjl8NKAzM8R33Wt+luS/3s+d7xG+CPNHeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
Does this work?
Lemma out_of_thin_air : forall {T1 T2: Prop},
T1 = T2 -> T1 -> T2.
Proof.
destruct 1; apply id.
Qed.
Goal True <> False.
intro Heq.
destruct (@out_of_thin_air True False Heq I).
Qed.
On 2016-05-09 18:03, Jonathan Leivent wrote:
> Are you sure that thing is inhabited as you say? I can't prove it - I end
> up with subgoals like "True <> False", which I don't think can be proven.
> Even if it were, can't such a collapsing reduction be only about
> equalities, in much the same way that axiom K is only about equalities?
> -- Jonathan
> On 05/09/2016 05:12 PM, Jason Gross wrote:
>> You're playing with fire here. Consider the inductive type
>> Inductive foo (A : Type) (x : A) : A -> Type := Build_foo (y z : A) : x <>
>> y -> x <> z -> y <> z -> foo A x x.
>> Then [foo Set True True] is inhabited (let y be False and z be bool), but
>> [foo Prop True True] contradicts prop_extensionality+LEM and so cannot be
>> inhabited.
>> What rule for universes of inductive types can you formulate that permits
>> what you want for equality but forbids collapsing [foo Set True True] is to
>> [foo Prop True True]?
>> On Mon, May 9, 2016, 4:01 PM Jonathan Leivent
>> <jonikelee AT gmail.com>
>> wrote:
>>> On 05/09/2016 03:48 PM, Stefan Monnier wrote:
>>>>> Note that [@eq Type@{i} A B -> @eq Type@{j} A B] does not hold for [i
>>>> j],
>>>> Hmm.. which part of Coq's typing rules cause this?
>>>> Stefan
>>> I'd just like to make it go away. Specifically, I'd like [@eq Type@{i}
>>> A B] to reduce to [@eq Type@{j} A B] where j is the minimum permissible
>>> level considering A and B.
>>> I guess one could have a type theory where some things are provably
>>> equal at higher levels but not at lower ones. But, such a thing seems
>>> quite bizarre.
>>> -- Jonathan
Attachment: signature.asc
Description: OpenPGP digital signature
