coq-club - Re: [Coq-Club] question about universes and equalities
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 18:03:57 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f41.google.com
  • Ironport-phdr: 9a23:FY5DIhTBAYLs2P61xpnqx4SLZ9psv+yvbD5Q0YIujvd0So/mwa64Zx2N2/xhgRfzUJnB7Loc0qyN4/GmADdLuc3JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuKOE4Q33KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzA0lRxBHwjM6lneU5bvvy3m/r5/3y+bPsDyQL0cVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
Are you sure that thing is inhabited as you say? I can't prove it - I end up with subgoals like "True <> False", which I don't think can be proven.
Even if it were, can't such a collapsing reduction be only about equalities, in much the same way that axiom K is only about equalities?
-- Jonathan
On 05/09/2016 05:12 PM, Jason Gross wrote:
You're playing with fire here. Consider the inductive type
Inductive foo (A : Type) (x : A) : A -> Type := Build_foo (y z : A) : x <>
y -> x <> z -> y <> z -> foo A x x.
Then [foo Set True True] is inhabited (let y be False and z be bool), but
[foo Prop True True] contradicts prop_extensionality+LEM and so cannot be
inhabited.
What rule for universes of inductive types can you formulate that permits
what you want for equality but forbids collapsing [foo Set True True] is to
[foo Prop True True]?
On Mon, May 9, 2016, 4:01 PM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
On 05/09/2016 03:48 PM, Stefan Monnier wrote:
Note that [@eq Type@{i} A B -> @eq Type@{j} A B] does not hold for [i
j],
Hmm.. which part of Coq's typing rules cause this?
Stefan
I'd just like to make it go away. Specifically, I'd like [@eq Type@{i}
A B] to reduce to [@eq Type@{j} A B] where j is the minimum permissible
level considering A and B.
I guess one could have a type theory where some things are provably
equal at higher levels but not at lower ones. But, such a thing seems
quite bizarre.
-- Jonathan
