- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT normalesup.org>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 14:07:49 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jacques-henri.jourdan AT normalesup.org; spf=Neutral smtp.mailfrom=jacques-henri.jourdan AT normalesup.org; spf=None smtp.helo=postmaster AT ulminfo.fr
- Ironport-phdr: 9a23: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
>> As I explained, that is because A:Prop implies A:Set holds, but the
>> converse does not.
> Not even when:
> - Prop and Set have no inhabitants
> - or Prop and Set have the same inhabitants
The thing is that Prop and Set DO HAVE inhabitants, and some of the ones
of Set are not in Prop. Always. Even when using -noinit, because you can
always redefine the standard library logical connectives using
inductives, which are primitive in the logic.
>> So Prop is strictly smaller than Set.
>> There is absolutely nothing theoretically fancy here, so I am not sure
>> to understand where the confusion comes from.
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Guillaume Melquiond, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Maxime Dénès, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Guillaume Melquiond, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jacques-Henri Jourdan, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dominique Larchey-Wendling, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Bruno Barras, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
