- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT normalesup.org>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 15:54:02 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jacques-henri.jourdan AT normalesup.org; spf=Neutral smtp.mailfrom=jacques-henri.jourdan AT normalesup.org; spf=None smtp.helo=postmaster AT ulminfo.fr
- Ironport-phdr: 9a23:dRhVRBCrLOa3/wMooS17UyQJP3N1i/DPJgcQr6AfoPdwSP3yocbcNUDSrc9gkEXOFd2CrakV16yK6uu+ACRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2as8Pi3OervpbXfg9ghTynYLo0Ig/lgx/Ws5w0iIB7N6sqjzvEpGFJM8ZR2HlkLFTbyxT17d6t8YUm8ylWofNn9cldS6nzeYw+SqZdBTArKH0tosrxuk+QHkO0+nIAXzBOwVJzCA/f4USiUw==
Yes, that is what I mean : if you remove -noinit, you cannot access
these definitions, but you can still create them again.
Le 19/01/2017 à 15:09, Dominique Larchey-Wendling a écrit :
> Le 19/01/2017 à 14:07, Jacques-Henri Jourdan a écrit :
>> The thing is that Prop and Set DO HAVE inhabitants, and some of the ones
>> of Set are not in Prop. Always. Even when using -noinit, because you can
>> always redefine the standard library logical connectives using
>> inductives, which are primitive in the logic.
> Well actually, "exists", /\, \/, True and False are inductively defined
> in the standard library ...
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Maxime Dénès, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Guillaume Melquiond, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Bruno Barras, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/19/2017
