- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>, agda-list <agda AT lists.chalmers.se>, Coq Discourse <coq+miscellaneous AT discoursemail.com>
- Subject: Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?
- Date: Wed, 04 Mar 2020 14:22:14 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mechvel AT scico.botik.ru; spf=Pass smtp.mailfrom=mechvel AT scico.botik.ru; spf=None smtp.helo=postmaster AT mail.botik.ru
- Ironport-phdr: 9a23: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
On 2020-03-04 02:04, Jason Gross wrote:
I'm confused by this. Are you saying that in Agda typechecking is
exponential in the number of files? Or exponential in the number of
nested abstractions? Or something else? Do you have a toy example
demonstrating this behavior?
No toy example, so far, but I think such can be provided.
I have a real-world example of the DoCon-A library for algebra:
http://www.botik.ru/pub/local/Mechveliani/docon-A/2.02/
This is a small part of the intended general purpose library for algebra
(for algebra methods, it is very small, but comparing to the Agda practice, it is large).
It is written in install.txt
"for the -M15G key (15 Gb heap) installation takes about 50 minutes on a
3 GHz personal computer.
It looks like the type checker has exponential cost in the depth of the tree of the
introduced parametric module instances.
There is a hierarchy of "classes" (classical abstract structures):
Magma, (commutative)Semigroup, (Commutative)Monoid, (Commutative)Group, ... ,
(Commutative)Ring, Field, IntegralDomain, EuclideanDomain, GCDDomain, LeftModuleOverARing ...
-- this tree depth may grow up to, may be, about 25.
And there are domain constructors: integer, vector, fraction, polynomial, residueRing ...
And these constructors are provided with instances of some of the above abstract structures.
These instances include implementation for their needed operations, with proofs.
The type checker deals with a hierarchy of such instances. And it performs evaluation
(normalization ...) with very large terms representing these instances.
For example, the Integer domain has may be 20 instances in it, and this large term is
substituted many times on other terms, because almost every domain uses some features of
the Integer domain. Anyway there appear internally very large terms that repeat many
times, and their embracing terms need to normalize.
Further, the domain
Vector (EuclideanRingResidue f (Polynomial (Fraction Integer))) (D)
is supplied with five instances of Magma, five instances of Semigroup,
five instances of CommutativeSemigroup, five instances of Monoid,
five instances of CommutativeMonoid, and also many other instances.
And the class operations in these instances (and their proofs) are implemented
each in its individual way.
The number of different instances of the classical operations grows exponentially
in the constructor depth for the domains like (D).
I do not expect that in mathematical textbooks appear domain constructs as (D)
of the level greater than 10.
But Agda has practical difficulties with the level of about 4.
Because each construct like (D) is further substituted to different parametric modules.
Because the method M1 uses one item from (D), so it is implemented in the environment of
a parametric program module to which (D) is substituted for a parameter,
the method M2 uses another item from (D), and so on. And large subterms get internally copied.
In a mathematical textbook, all these substitutions are mentioned or presumed, and are
understood by the reader. So the informal "rigorous" proofs fit, say, 200 pages
(~ 100 Kb of memory).
But when a type checker tries to understand these constructions, it creates many copies of large subterms and spends the cost in normalizing them.
And formal proofs take 15 Gb memory to check.
First, this copy eagerness can probably be reduced (probably, this is not easy to implement).
Second, something can be needed to arrange in the style of the application programs.
There is a paper of Coq about this style, I recall A.Mahboubi is among the authors.
So, there is a fundamental restriction -- which hopefully can be handled by introducing a certain
programming style (I never looked into this).
And also there is probably something to fix in the type checker in Agda.
Regards,
Sergei
There is a problem of the type checking cost in Agda, and probably
in Coq too.
I do not know of whether it is fundamental or technical. And I have
not seen an answer to this question, so far. On practice, it looks like
this:
Agda can type-check only a small part of the computer algebra
library of
methods (with full proofs). With implementing it further, with
increasing the hierarchy level of parameterized modules, the type
check cost seems to grow exponentially in the level.
So, after implementing in Agda an average textbook on computer
algebra
(where is known a constructive proof for each statement), say, of
500 pages, it will not be type-checked in 100 years.
Probably, this is a difficult technical problem that will be
practically solved during several years.
- [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] [lean-user] Why dependent type theory?, Colin Stebbins Gordon, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Viktor Kunčak, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Patricia Peratto, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Jason Gross, 03/04/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/06/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/07/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ulf Norell, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
