- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>, agda-list <agda AT lists.chalmers.se>, Coq Discourse <coq+miscellaneous AT discoursemail.com>
- Subject: Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?
- Date: Sat, 07 Mar 2020 16:30:54 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mechvel AT scico.botik.ru; spf=Pass smtp.mailfrom=mechvel AT scico.botik.ru; spf=None smtp.helo=postmaster AT mail.botik.ru
- Ironport-phdr: 9a23:Vc0H+hzqtKweELnXCy+O+j09IxM/srCxBDY+r6Qd0uIVIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2TxTor3az9T8fHAnkfUowf7ytW92as8Pi9emp/JubTB9PnyH1NbF7NxKwoh/WrdJHqYRnI6c1jBDOpy0bVf5RwDZtKFmTgRv4zty7/ZVktS5Xp/MisdRdAvayRLgxUbENVGduCGsy/sC+8ECbFVLStEtZaX0fl19zOyaA7Bz+Wc6s4C7zt+470i6GPM6wV61mAW3zvZcucwfhjWI8DxB89WjWjsJqi6cC/kC6rB10xMjeZ52UN7xkY/GEJI9IdS96Rs9UEhd5LMakdYJWUbgaNudTqM/3oEcPrl2kGFv0CQ==
I tried an example with the direct product of many domains.
It fails to "break" the Agda type checker
(Development of March 5, 2020).
This was
R₀ = (ℕₛ ×ₛ (ℤₛ ×ₛ (ℕₛ ×ₛ (ℕᵇₛ ×ₛ (ℤᵇₛ ×ₛ ℚₛ))))) ×ₛ ℚₛ
R = R₀ ×ₛ R₀
open Semiring R using (Carrier; _≈_; refl; 1#; *-monoid)
open Monoid-theory *-monoid using (_^_)
open Semiring-theory R using (sum; fromℕ)
res : Carrier
res = (sum (1# ∷ 1# ∷ [])) ^ 3
theorem : res ≈ fromℕ 8
theorem = refl {res}
It uses the semirings of
ℕ, ℤ, ℕᵇ (binary natural), ℤᵇ (binary integer), ℚₛ (fraction over Integer).
This Test.agda is type-checked within the same minimum of 1 Gb space
and in almost the same time
(provided that all other needed modules of the applied and standard libraries are type-checked)
almost independently on the number of the domains in the expression for R₀.
The domains in the direct product are too independent ...
Sergei
On 2020-03-06 22:40,
wrote:
Continuing a sub-discussion about the type check performance,
I add that I have tried now the current Development Agda version
(March 5, 2020).
I compare it to the last official version of 2.6.0.1
at a certain BFLib project (Binary Integer + General Fraction arithmetcic).
This library is may be 5 times smaller than DoCon-A, but it is large
in comparison to
usual Agda application practice.
It is applied
> time agda $agdaLibOpt BRationalTest.agda +RTS -M<size> -RTS
(on ghc-8.8.3, Ubuntu Linux 18.04, 3 GHz personal computer)
which type-checks everything in the given memory space.
Development Agda type-checks it in the minimum of 1400 Mb memory,
it is about 1.5 times less space eager and 20% faster.
This gives a certain hope, assuming that 2.6.0.1 probably wins
something relatively to
the versions of 2017.
This needs testing and effort in upgrading DoCon-A.
Regards,
Sergei
On 2020-03-04 20:07,
wrote:
On 2020-03-04 14:22,
wrote:
On 2020-03-04 02:04, Jason Gross wrote:
I'm confused by this. Are you saying that in Agda typechecking is
exponential in the number of files? Or exponential in the number of
nested abstractions? Or something else? Do you have a toy example
demonstrating this behavior?
No toy example, so far, but I think such can be provided.
I have a real-world example of the DoCon-A library for algebra:
http://www.botik.ru/pub/local/Mechveliani/docon-A/2.02/
This is a small part of the intended general purpose library for algebra
(for algebra methods, it is very small, but comparing to the Agda
practice, it is large).
It is written in install.txt
"for the -M15G key (15 Gb heap) installation takes about 50 minutes on a
3 GHz personal computer.
I am sorry.
I need to add the following.
This as about the Agda versions of about 2017.
It may occur that the current Agda version improves something there.
This needs testing, needs more effort in porting the library.
I use the last Agda versions, but on certain smaller projects.
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
- [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] [lean-user] Why dependent type theory?, Colin Stebbins Gordon, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Viktor Kunčak, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Patricia Peratto, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Jason Gross, 03/04/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/06/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/07/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ulf Norell, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Christian Doczkal, 03/03/2020
