coq-club - Re: [Coq-Club] Program Fixpoint and Nested fix expressions
  • From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Program Fixpoint and Nested fix expressions
  • Date: Mon, 14 Sep 2020 11:55:52 +0200
Hi Tj,
> Le 14 sept. 2020 à 09:28, Tj Barclay <tjbarclay AT ku.edu> a écrit :
> Enclosed is an arbritrary example (Coq 8.11.2) of an attempt to show
> termination of a recursive function on the size of a nested-recursive
> datatype.
> Is it possible for the obligation generated by the recursive call to
> 'flatten' inside the nested fix, 'flatten_list', to also generate
> hypotheses relating the matched list 'l' and the parameter 'arbs'? In
> particular, that 'arbs' will always be a sublist of 'l' or that the
> matched pair '(_,a')' has the property 'In (_,a') l'
> (* Function in question *)
> Program Fixpoint flatten (a : arb) {measure (size_arb a)}: list nat :=
> match a with
> | A n => [n]
> | B n l => n :: (fix flatten_list (arbs : list (nat * arb)) : list nat :=
> match arbs with
> | (n',a')::arbs' => n' :: (flatten a' ++ flatten_list
> arbs')
> end) l
> end.
> Obligation 1.
> (* Example End *)
For this to work I think you will need to explicitly pass around a proof
witness
that `size arbs <= size l` (or `size arbs < size a`) in the `flatten_list`
fixpoint,
otherwise there is no (semantic) link between `arbs` in the fixpoint and the
argument
`l` to which it is applied.
Best,
— Matthieu
