- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Program Fixpoint and Nested fix expressions
- Date: Mon, 14 Sep 2020 15:51:29 +0200
- Organization: LORIA
Hi,
Having worked with rose trees (finite trees with unbounded branching)
quite a lot, I would give you the following feedback.
Do not use the inductive definition of Forall' (lifted to Type)
because you are going to need to duplicate a lot of the results
that already exist for Forall (Prop) anyway.
I would suggest using the non-inductive definition:
Forall' P l := forall x, In x l -> P x
This one is much easier to work with.
If you need the position information in "In x l" (which is
available in your inductive definition of Forall'), lift
"In" to Type, ie
In_t : forall X, X -> list X -> Type
In_t x nil := False
In_t x (y::l) := (x = y) + (In_t x l)
but my experience is that it is rarely needed to
have the position information.
Then write the dependent recursor "arb_rect" and prove
fixpoint equations (under some extensionality assumption)
using Fix_F from Wf, see below.
You can specialize the generalized recursor with
non-dependent output type as eg "arb_recursion"
and then fixpoint equations come w/o extensionality
assumptions.
Then you can systematically use the specialize
recursor "arb_recursion" for your definitions
and fixpoint equations are easily derived.
In your example, this would give the following, see below.
Best,
Dominique
Require Import Wf.
Require Import List.
Import ListNotations.
Set Implicit Arguments.
Unset Elimination Schemes.
Inductive arb : Type :=
| A : nat -> arb
| B : nat -> list (nat * arb) -> arb.
Set Elimination Schemes.
Section arb_rect.
Let R (x y : arb) :=
match y with
| A _ => False
| B _ l => exists n, In (n,x) l
end.
Fixpoint Rwf x : Acc R x.
Proof.
destruct x as [ n | n l ].
+ constructor; inversion 1.
+ constructor; intros x (m & Hm).
revert l Hm; refine (fix loop l := _).
destruct l as [ | (k,y) l ].
* intros [].
* intros [ E | H ].
- generalize (Rwf y).
inversion E; trivial.
- apply (loop l), H.
Qed.
Variables (P : arb -> Type)
(H1 : forall (n : nat), P (A n))
(H2 : forall (n : nat) (l : list (nat * arb)), (forall p, In
p l -> P (snd p)) -> P (B n l)).
Definition arb_rect : forall a, P a.
Proof.
apply Fix with (1 := Rwf).
intros [ n | n l ] H.
+ apply H1.
+ apply H2.
intros (m,x) Hmx.
apply H; exists m; trivial.
Defined.
Hypothesis H2_ext : forall n l f g, (forall p Hp, f p Hp = g p Hp) ->
H2 n l f = H2 n l g.
Fact arb_rect_fix_1 n : arb_rect (A n) = H1 n.
Proof.
unfold arb_rect at 1.
unfold Fix.
now rewrite <- Fix_F_eq.
Qed.
Fact arb_rect_fix_2 n l : arb_rect (B n l) = H2 n l (fun p _ =>
arb_rect (snd p)).
Proof.
unfold Fix.
apply H2_ext.
intros (m,b) H.
Search Fix_F.
apply Fix_F_inv.
+ red; apply Rwf.
+ intros []; auto.
intros f g Hfg; apply H2_ext.
intros [] ?; apply Hfg.
Qed.
End arb_rect.
Definition arb_rec (P : arb -> Set) := arb_rect P.
Definition arb_ind (P : arb -> Prop) := arb_rect P.
Section list_In_map.
Variable (X Y : Type).
Fixpoint list_In_map l : (forall x : X, In x l -> Y) -> list Y.
Proof.
refine (match l with
| [] => fun _ => []
| x::l => fun f => f x _ :: list_In_map l _
end).
+ left; trivial.
+ intros x' ?; apply (f x'); right; trivial.
Defined.
Fact list_In_map_ext l f g :
(forall x Hx, f x Hx = g x Hx)
-> list_In_map l f = list_In_map l g.
Proof.
revert f g; induction l as [ | x l IHl ]; simpl; f_equal; auto.
intros f g Hfg; rewrite Hfg; f_equal.
apply IHl.
intros; apply Hfg.
Qed.
Variable (f : X -> Y).
Fact list_In_map_map l : list_In_map l (fun x _ => f x) = map f l.
Proof. induction l; simpl; f_equal; auto. Qed.
End list_In_map.
Section arb_recursion.
Variables (T : Type)
(f1 : nat -> T)
(f2 : nat -> list (nat*T) -> T).
Definition arb_recursion : arb -> T.
Proof.
apply arb_rect.
+ apply f1.
+ intros n l Hl.
apply (f2 n).
apply (list_In_map l).
intros p Hp; split.
* apply (fst p).
* apply (Hl _ Hp).
Defined.
Fact arb_recursion_fix_1 n : arb_recursion (A n) = f1 n.
Proof.
unfold arb_recursion.
now rewrite arb_rect_fix_1.
Qed.
Fact arb_recursion_fix_2 n l : arb_recursion (B n l) = f2 n (map (fun
'(i,a) => (i,arb_recursion a)) l).
Proof.
rewrite arb_rect_fix_2.
+ f_equal.
rewrite list_In_map_map.
apply map_ext.
intros []; simpl; auto.
+ intros; f_equal; apply list_In_map_ext.
intros; f_equal; auto.
Qed.
End arb_recursion.
Definition flatten : arb -> list nat.
Proof.
apply arb_recursion.
+ intros n; exact [n].
+ intros n l; exact (n::flat_map (fun c => snd c) l).
Defined.
Fact flatten_fix_1 n : flatten (A n) = [n].
Proof. apply arb_recursion_fix_1. Qed.
Fact flatten_fix_2 n l : flatten (B n l) = n::flat_map (fun p => flatten
(snd p)) l.
Proof.
unfold flatten at 1.
rewrite arb_recursion_fix_2; f_equal.
rewrite !flat_map_concat_map, map_map; f_equal.
apply map_ext; intros []; auto.
Qed.
Le 14/09/2020 à 09:28, Tj Barclay a écrit :
> Enclosed is an arbritrary example (Coq 8.11.2) of an attempt to show
> termination of a recursive function on the size of a nested-recursive
> datatype.
> Is it possible for the obligation generated by the recursive call to
> 'flatten' inside the nested fix, 'flatten_list', to also generate
> hypotheses relating the matched list 'l' and the parameter 'arbs'? In
> particular, that 'arbs' will always be a sublist of 'l' or that the
> matched pair '(_,a')' has the property 'In (_,a') l'.
> (* Example Start *)
> Require Import Coq.Program.Wf <http://Coq.Program.Wf>.
> Inductive Forall' (A : Type) (P' : A -> Type) : list A -> Type :=
> | Forall_nil' : Forall' A P' []
> | Forall_cons' : forall (x : A) (l : list A), P' x -> Forall' A P' l ->
> Forall' A P' (x :: l).
> | A : nat -> arb
> Definition arb_rect_helper (P : arb -> Type) (p : nat * arb) : Type :=
> match p with
> | (x, y) => P y
> end.
> Fixpoint arb_rect (P : arb -> Type)
> (H2 : forall (n : nat) (l : list (nat * arb)), Forall' (nat *
> arb) (arb_rect_helper P) l -> P (B n l))
> (a : arb) : P a :=
> match a return (P a) with
> | A n => H1 n
> | B n l => let fix loop (l : list (nat * arb)) :=
> match l with
> | [] => Forall_nil' (nat * arb) (arb_rect_helper P)
> | (n',a')::l' => Forall_cons' (nat * arb)
> (arb_rect_helper P) (n',a') l' (arb_rect P H1 H2 a') (loop l')
> end
> in
> H2 n l (loop l)
> end.
> Set Eliminate Schemes.
> Fixpoint size_arb (a : arb) : nat :=
> match a with
> | A _ => 1
> | B _ l => 1 + (fix size_list (l : list (nat * arb)) : nat :=
> match l with
> | [] => 0
> | (_,a')::l' => size_arb a' + size_list l'
> end) l
> end.
> (* Function in question *)
> Program Fixpoint flatten (a : arb) {measure (size_arb a)}: list nat :=
> match a with
> | A n => [n]
> | B n l => n :: (fix flatten_list (arbs : list (nat * arb)) : list nat :=
> match arbs with
> | (n',a')::arbs' => n' :: (flatten a' ++ flatten_list
> arbs')
> end) l
> end.
> Obligation 1.
> (* Example End *)
> Best,
> TJ
> TJ Barclay
> Electrcial Engineering & Computer Science, University of Kansas
> tjbarclay AT ku.edu <mailto:tjbarclay AT ku.edu>
> +1 316 259 2250
- [Coq-Club] Program Fixpoint and Nested fix expressions, Tj Barclay, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Castéran Pierre, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Matthieu Sozeau, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Dominique Larchey-Wendling, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Christian Doczkal, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Gert Smolka, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Jim Fehrle, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Matthieu Sozeau, 09/15/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Dominique Larchey-Wendling, 09/15/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Tj Barclay, 09/15/2020
