- From: Christian Doczkal <christian.doczkal AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Program Fixpoint and Nested fix expressions
- Date: Mon, 14 Sep 2020 18:42:29 +0200
It might be worthwhile to point out that the particular example you give is
indeed structurally recursive. That is, the following, which is basically
just removing the "Program" and "{measure _}" parts actually works:
Require Import List.
Import ListNotations.
Set Implicit Arguments.
Inductive arb : Type :=
| A : nat -> arb
| B : nat -> list (nat * arb) -> arb.
Fixpoint flatten (a : arb) : list nat :=
match a with
| A n => [n]
| B n l => n :: (fix flatten_list (arbs : list (nat * arb)) : list nat :=
match arbs with
| (n',a')::arbs' => n' :: (flatten a' ++ flatten_list
arbs')
end) l
end.
Unfortunately, I don't remember the precise rules that make this definition
okay. It's something along the lines of "l" being structurally smaller than
"a" and "flatten_list" applying flatten only to arguments that are
"structurally no greater than y". However, this seems to not be covered by
relevant section of the current manual:
https://coq.inria.fr/refman/language/core/inductive.html#id10
Maybe someone can chime in and provide the precise rules making this legal.
By the way, one can also make this slightly more readable by factoring out
flatten_list.
Definition flatten_list (f : arb -> list nat) : list (nat * arb) -> list nat
match arbs with
| (n',a')::arbs' => n' :: (f a' ++ flatten_list arbs')
end).
match a with
| A n => [n]
| B n l => n :: flatten_list flatten l
end.
This pattern is used extensively throughout the mathematical components
library. Note that replacing the definition with the more standard
Fixpoint flatten_list (f : arb -> list nat) (arbs : list (nat * arb)) := ...
does *not* work, because this would lead to "flatten" not being applied to
any arguments in the clause for "B", even after the reduction that is
happening before checking the guard condition.
Best,
Christian
On 9/14/20 9:28 AM, Tj Barclay wrote:
> Enclosed is an arbritrary example (Coq 8.11.2) of an attempt to show
> termination of a recursive function on the size of a nested-recursive
> datatype.
> (* Function in question *)
> Program Fixpoint flatten (a : arb) {measure (size_arb a)}: list nat :=
> match a with
> | A n => [n]
> match arbs with
> arbs')
> end) l
> end.
> Obligation 1.
> (* Example End *)
- [Coq-Club] Program Fixpoint and Nested fix expressions, Tj Barclay, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Castéran Pierre, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Matthieu Sozeau, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Dominique Larchey-Wendling, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Christian Doczkal, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Gert Smolka, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Jim Fehrle, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Matthieu Sozeau, 09/15/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Dominique Larchey-Wendling, 09/15/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Tj Barclay, 09/15/2020
