coq-club - Re: [Coq-Club] Program Fixpoint and Nested fix expressions
  • From: Christian Doczkal <christian.doczkal AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Program Fixpoint and Nested fix expressions
  • Date: Mon, 14 Sep 2020 22:33:31 +0200
On 9/14/20 8:16 PM, Gert Smolka wrote:
> Smiley! What you are referring to is the guard condition, which was
> extended over the years but never documented.
Was it really never documented? I was referring to the slides from Bruno
Barras (from some unknown event in 2010, probably some Coq developer meeting)
that has a rule for nested fixpoints:
https://coq.inria.fr/files/adt-2fev10-barras.pdf (Slide 15).
But without the explanations, the rules are pretty much indigestible. I guess
it's not too surprising that his example is indeed the size function for
trees (which relies on the fold_right in the standard library being defined
by pulling the function-argument out of the fixpoint):
Inductive tree := T (A: list tree).
Fixpoint size (t:tree) :=
match t with T A => fold_right (fun t' n => n+size t') 1 A end.
My question was: what precisely makes the t' from the above
lambda-abstraction smaller than t.
Funny aside: the conclusion of said talk (10 years ago) was: "Syntactic
criteria are dead".
Best,
Christian
