- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Program Fixpoint and Nested fix expressions
- Date: Tue, 15 Sep 2020 10:36:42 +0200
Hi,
> Le 14 sept. 2020 à 22:33, Christian Doczkal <christian.doczkal AT inria.fr> a
> écrit :
> On 9/14/20 8:16 PM, Gert Smolka wrote:
>> Smiley! What you are referring to is the guard condition, which was
>> extended over the years but never documented.
> Was it really never documented? I was referring to the slides from Bruno
> Barras (from some unknown event in 2010, probably some Coq developer
> meeting) that has a rule for nested fixpoints:
> https://coq.inria.fr/files/adt-2fev10-barras.pdf (Slide 15).
> But without the explanations, the rules are pretty much indigestible. I
> guess it's not too surprising that his example is indeed the size function
> for trees (which relies on the fold_right in the standard library being
> defined by pulling the function-argument out of the fixpoint):
> Inductive tree := T (A: list tree).
> Fixpoint size (t:tree) :=
> match t with T A => fold_right (fun t' n => n+size t') 1 A end.
> My question was: what precisely makes the t' from the above
> lambda-abstraction smaller than t.
The guard condition allows itself to delta and beta-reduce the body of a
fixpoint to check for termination.
In doing so, it unfolds the fold_right and substitutes the function inside
it. In addition,
when guard-checking `(fix F arg { struct arg } := body) A`, the `body` of the
fixpoint
is guard-checked with the assumption that the size of `arg` is less than or
equal to the size of
`A` [1]. This is where the magic happens. Now when checking the unfolded
fold_right the `size t’`
call will have simplified to some `size arg’` where `arg’ < arg <= A < t`
making the recursive
call to size legit.
> Funny aside: the conclusion of said talk (10 years ago) was: "Syntactic
> criteria are dead ».
Maybe it is a good place to mention that their is current work by Jonathan
Chan and William Bowman
to implement a sized type checker for Coq [2]. As far as I understand, the
main current limitation
is that it cannot handle such nested types without introducing polarities in
inductive definitions.
[1]
https://github.com/coq/coq/blob/60960284237b295f8b82e07119e1ba1467b9a1de/kernel/inductive.ml#L1057
[2] https://github.com/coq/coq/pull/12426
— Matthieu
- [Coq-Club] Program Fixpoint and Nested fix expressions, Tj Barclay, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Castéran Pierre, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Matthieu Sozeau, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Dominique Larchey-Wendling, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Christian Doczkal, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Gert Smolka, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Jim Fehrle, 09/14/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Matthieu Sozeau, 09/15/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Dominique Larchey-Wendling, 09/15/2020
- Re: [Coq-Club] Program Fixpoint and Nested fix expressions, Tj Barclay, 09/15/2020
