coq-club - Re: [Coq-Club] Program Fixpoint and Nested fix expressions
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Program Fixpoint and Nested fix expressions
  • Date: Mon, 14 Sep 2020 20:16:01 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=smolka AT ps.uni-saarland.de; spf=Pass smtp.mailfrom=smolka AT ps.uni-saarland.de; spf=None smtp.helo=postmaster AT triton.rz.uni-saarland.de
  • Ironport-phdr: 9a23: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
On 14. Sep 2020, at 18:42, Christian Doczkal <christian.doczkal AT inria.fr> wrote:
Unfortunately, I don't remember the precise rules that make this definition okay. It's something along the lines of "l" being structurally smaller than "a" and "flatten_list" applying flatten only to arguments that are "structurally no greater than y". However, this seems to not be covered by relevant section of the current manual: https://coq.inria.fr/refman/language/core/inductive.html#id10
Maybe someone can chime in and provide the precise rules making this legal.
Smiley!  What you are referring to is the guard condition, which was extended over the years but never documented.
Anyway, nested inductive types (e.g., rose trees) are impossible without the extended guard condition.
BTW, someone should delete the reference to Giménez in the reference Manual:
"Before accepting a fixpoint definition as being correctly typed, we check that the definition is “guarded”. A precise analysis of this notion can be found in [Gimenez94].”
At this point there was only a minimal guard condition.
I’m intrigued by Dominique’s idea to define the eliminator for rose trees with ACC.  Below is a minimal version.
It shows that the extended guard condition can be quite nice.
Cheers, Gert
Inductive tree := T (A: list tree).
Implicit Type s t: tree.
Definition dst s t := let (A) := t in In s A.
Fixpoint tree_Acc t: Acc dst t.
Proof.
 destruct t as [A].
 constructor.
 induction A as [| t A IH]; cbn.
 - intros t [].
 - intros s [[]|H].
   + apply tree_Acc.
   + apply IH, H.
Defined.
Eval cbv -[dst] in tree_Acc.
