Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Failed assert in copy_driver.c
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Xavier Lacoste <xl64100@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Failed assert in copy_driver.c
  • Date: Mon, 20 Oct 2014 12:37:32 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Xavier Lacoste, le Mon 20 Oct 2014 11:37:50 +0200, a écrit :
> I'm trying to use MPI together with GPU on curie from CCRT using StarPU 1.2.
Which revision is it precisely?
> On some of my runs I got this error :
> oops in copy_data_1_to_1_generic (datawizard/copy_driver.c:200)... 4:
> unspecified launch failure
> Do you have any advice to avoid/fix that ?
Mmm, CUDA doesn't seem helpful as to what it doesn't like... Perhaps
there are too many transfers at the same time, you can try to reduce
that in src/datawizard/data_request.c's MAX_PENDING_REQUESTS_PER_NODE
and MAX_PENDING_PREFETCH_REQUESTS_PER_NODE.
Samuel
Haut de le page
