Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Failed assert in copy_driver.c
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Failed assert in copy_driver.c
  • Date: Mon, 20 Oct 2014 13:56:08 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Le 20 oct. 2014 à 13:46, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Xavier Lacoste, le Mon 20 Oct 2014 13:38:36 +0200, a écrit :
>>> Xavier Lacoste, le Mon 20 Oct 2014 11:37:50 +0200, a écrit :
>>>> I'm trying to use MPI together with GPU on curie from CCRT using StarPU
>>>> 1.2.
>>> Which revision is it precisely?
>> It's revision 13560.
> You should try at least r13658, I introduced a bug in r13630 which may
> be related with what you are getting.
Ok thanks, i'll have a look.
> BTW, why do you use 1.2 and not 1.1?
I could use 1.1, the only thing I use from 1.2 are the commutable tasks but
in my code. The use of this feature does not change much the timing of the
execution, so I can go 1.1...
it's just because I used 1.2 on an other machine (when I tested the removal
of sequential consistency flag on often used buffers) and wanted the same
configuration.
> Samuel
Attachment: signature.asc
Description: Message signed with OpenPGP using GPGMail
Haut de le page
