Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Failed assert in copy_driver.c
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Failed assert in copy_driver.c
  • Date: Mon, 20 Oct 2014 13:38:36 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Le 20 oct. 2014 à 12:37, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Hello,
> Xavier Lacoste, le Mon 20 Oct 2014 11:37:50 +0200, a écrit :
>> I'm trying to use MPI together with GPU on curie from CCRT using StarPU
>> 1.2.
> Which revision is it precisely?
It's revision 13560.
>> On some of my runs I got this error :
>> oops in copy_data_1_to_1_generic (datawizard/copy_driver.c:200)... 4:
>> unspecified launch failure
>> Do you have any advice to avoid/fix that ?
> Mmm, CUDA doesn't seem helpful as to what it doesn't like... Perhaps
> there are too many transfers at the same time, you can try to reduce
> that in src/datawizard/data_request.c's MAX_PENDING_REQUESTS_PER_NODE
> and MAX_PENDING_PREFETCH_REQUESTS_PER_NODE.
Ok i'll rerun my code with 2/1 instead of 20/10
Thanks
> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Attachment: signature.asc
Description: Message signed with OpenPGP using GPGMail
Haut de le page
